XR250
- Jan 30, 2013
- 6,001
I have a job where a residential foundation wall is pushing in significantly. It is in a room with a formed-in-place porch slab above and a slab-on-grade below. The height of the foundation wall is 6 ft. A driveway is adjacent to this area that they do not want to disturb at this time. The wall is too far gone for soldier beams to be effective IMHO.
The contractor has suggested created a one-sided form on the inside face of the CMU creating a reinforced concrete wall. The rebar would be doweled into the upper and lower slabs. He would core holes in the slab above to fill the wall with a 2" pump. The contractor only has a 2" pump that he uses for slab-jacking and it can only pump sand mix concrete. Is there a mix design that will work for this situation? Is there a reason we cant use ASTMC476 Fine Grout Mix with some shrinkage reducing admixtures or something like that. Shrinkage cracks will be acceptable from an aesthetic standpoint.
I supposes he could also rent a pump that can handle pea gravel but we are trying to keep the costs down.
Thanks!
Thanks!
