Salt quality for softening system??
arguellesmanuel
Chemical
Mar 17, 2007
23
Good day, I know the reason why I can not use in my system Softening industrial salt with iodine and fluoride?
Currently it is difficult to get into this salt market and in my store there is only edible salt with iodine and fluorine.
I have two days softening salt for human consumption.
thanks.
Manuel Arguelles
Pharmaceutical Plant
Only use water softener salt because water softener salt should contain no substances such as iodine or fluoride, i.e. as few foreign substances (ions) as possible, that may impair the regeneration process.
The concentrations of fluoride in food grade salt used around the world range from 90 ppm to 350 ppm. Concentration of fluoride in European salts is approximately 250 ppm. The concentrations of iodine in food grade salt is approximately 30 ppm. Food grade salt also contains 1% Sodium Silicoaluminate and sodium ferrocyanide as anticaking agents.
The fluoride and iodine will probably not have any affect on the water softener. However the anticaking agents in food grade salt may foul the water softener resin.
ok thank you very much, my doubt was cleared.
Manuel Arguelles
