YungPlantEng
Chemical
We have a series of smaller softener units that take pre-softened water as an inlet and soften it additionally to make it "super soft". Essentially our bulk softener softens to a maximum of 5 ppm leakage and then these additional polishers are there in case the main softeners failed and went above 5 ppm.
Running through these systems with our vendor there is the ability to adjust salt dosage & capacity. I have trouble understanding what adjusting the "salt dosage" actually does. Does this reduce the amount of super-saturated brine drawn up in order to reduce the overall concentration during regeneration?
My understanding is that you can alter the salt dosage to improve your efficiency while risking hardness leakage. I wanted to adjust the actual capacity before each regen (flowmeter based system) understanding that the capacities were originally calculated assuming 17 gpg (300 ppm) hardness at the inlet. I thought we could just re-calculate the capacity to regen less often and base it off of say a 25 ppm inlet since that would be several times over the worst case scenario. The vendor said that what I would be doing is changing the salt dosage but one of us certainly seems misunderstood.
I'm basically asking for an understanding of what salt dosage is and how it is figured into the capacity calculation. I also wanted to understand if the resin bed would still be spent if very low ppm water was going through it (Would my capacity be 10x if my inlet hardness is 10x less then what was originally calculated?)
Thanks for any help!
