MedievalMan
Apparently, I'm a bit of an exception at my workplace: most of the engineers are hired directly to full-time, whereas I was hired through a recruitment firm (Aerotek) that they usually use mainly for the technicians (with the contract that I would be hired full-time after 6 months.)
I'm kind of a niche in my workplace: I'm the only software engineer (there are about 20 engineers in total, and the company I work for has been expanding quite a bit.) I'm enjoying my work, and have actually been able to apply stuff I learned in my bachelor's and master degrees (ECE and control systems engineering, respectively.)
From the grapevine at work (note that actual salaries are not disclosed and we are told to not share with fellow employees) I've learned that they typically pay the engineers a "probationary" salary for the first 3-6 months, with a decent increase after that.
I'm currently making $45K (which my thesis supervisor tells me "is too low, ask for more"). When I was hired on full-time after 3 months (instead of 6, since I was doing an exceptional job), they said I would be kept at the same salary with a raise soon in the future.
To add to the picture, my supervisor "accidentally" put an amount of $55K on the full-time offer letter (which he mentioned verbally many times.) I eventually had to correct him, as it was an oversight on his part: nevertheless, apparently, he seemed to think the amount was reasonable. I'm suspecting the $10K difference may have been the amount they were paying Aerotek?
My question is, upon 6 months, I think I'm going to ask for consideration for a raise. If a $ is asked about, I'm thinking about mentioning the $55K. Some of my friends (not work friends) seem to think that's high for a first raise, others seem to think it is reasonable. Considering in my first 5 months I've made programs that have enabled tests they haven't been able to run in 15 years, I'm thinking it many not be that unreasonable
Any thoughts on this situation?
This is my first permanent job (I've had many co-op placements before that, however) so I'd like some advice on how to approach the "first raise".
Also from the grapevine at work, it seems as your review for a raise at work doesn't come up unless you mention it.
Thanks in advance for any advice,
-Medieval
-Medieval
