SAFE V12 appears to give much higher punching shear ratios than V8 using the same code and same model, i.e. if you build a model in V12 and then export/run in V8 and use the same code you get very different answers. Columns that work in V8 suddenly don't work in V12.
Has anyone looked into this? The numbers are very very different, not just a few percentage points.
