I've been having a discussion on another forum about oil pressure limits. Our old 850 engines have a relief valve that is supposed, by design, to open at 45 psi, according to published data. On my engine the gauge pressure shows 55-65 psi at start from cold, then settles down to about 45-55 psi at cruise speed, with about 20 psi at idle. I consider this the normal thing.
One of the other participants in the discussion boasts that his engine is better because it shows 120 psi. I reckon this is likely to indicate a faulty oil pressure relief valve, or a faulty gauge.
If the gauge is correct, I think it could result in crank seal leakage.
Another issue is the possibility of increased wear of the skew gears driving his oil pump and distributor (on these old engines it's not completely unknown for them to let go altogether).
More importantly, I think the excess pressure might push open the bypass valve in his filter and allow unfiltered oil round the system.
Anyone here know at what pressure the average oil filter opens it's PRV?
