Dear sir,
I want to design a system whitch is using a S7 315-2DP CPU, MICROMASTER 440 and a Mobile Panel 170 to control the speed of a 22 KW motor which has a nominal speed of 1500rpm and is connected on a speed reducer with an output of 53rpm but i have some questions:
1.If i increase the freq. to 60hz how will the 4000 Nm will be affected?
2.What size should i use for the termomagnetical protection of the motor?
3.The length between the VFD and the motor is approx. 20 m should i use a normal 5 wire cable or a special one?
4.What software to use for parameterization of the VFD (which one is easier).
5.Before the use of the VFD i measure the load on the electric motor by using an clampmeter, will this still be effective?
