Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The buckling load capacity of a column made up of S355 or S275 is the same since modulus of elasticity for almost all steels the same..
You're assuming we know what you're talking about?
The axial capacity achieved is proportional to the yield strength after all.
Most non Americans would know or heard of these terms. They are commonly available European structural steel grades.
To clarify, given the same section size with different yield strengths, the one with the higher yield strength will have a higher buckling capacity under the same restraint conditions...
Often lower strength steels are more ductile (higher elongation when tested before fracturing)
Depending on the slenderness, the difference can be very small.
The question wasn't posed by OP about columns, that was raised by hturkuk. I was more discussing the material property differences between the different grades.
These are material specifications of course, but in general lower strength steels usually have a higher elongation requirement and hence elongation performance as I originally noted.
In the UK S355 is now the norm for beam and column sections. It will be more expensive to buy the same sections in S275, as these are not rolled regularly.
