I am trying to determine the typical conversion efficiency from SO2 to SO3 on the surface of a SCR catalyst.
We will install a gas fired combined cycle plant. The gas turbine will fire kerosene with 0.01% Sulphur by wt. The heat recovery steam generator will have a SCR located in a gas temperature zone at 650 F. We have a concern that the SO3 will react with the 5 ppm NH3 slip and form ammonium bisulphate.
Can anyone advise the estimated conversion efficiency to form SO3 from SO2 on such a catalyst?
