Dear forum members,
recently I have encountered the following issue when specify rupture discs - seems to be trivial, but the longer
I think the more questions are coming up:
Rupture disc is installed at the low pressure side of heat exchanger. Rupture disc outlet is connected to the flare system. Design pressure (MAWP not known so far)of heater low pressure side is 6 bar[g], constant flare back-pressure is established to 0.2 bar[g].
That's my first rupture disc specification. In my mind rupture disc are always mentally connected with differential pressure, which implies the following (regardless bursting tolerances, manufacturing ranges etc.):
Bursting pressure shall be established to 5.8 bar, what guarantees heat exchanger protection for conditions described.
Thus what about stamped bursting pressure of rupture disc - are they stamped for required pressure difference across the disc?
Based on which pressure value(s) vendor is specifying rupture discs? I have seen many offers in internet and mostly gauge pressure is given, what is only straightforward for non back-pressure affected installations.
How bursting pressure of rupture disc should be shown on P&IDs to do not confuse anybody - bar, somehow bar[g]?
I have searched API 520 and many internet threads, but I did not find full approach explained.
Would be appreciated if anybody is able to advise what is a the best way to to that.
Regards, dewed12
Regards, dewed12
