raytheyounger
Aerospace
I have a print of a part that is similar to a cylinder. One flat end of the cylinder has a flatness tolerance. The other end has a circular runout tolerance.
I think I understand circular runout if it is applied to the curved part of the cylinder. But I don't see how it applies to the flat surface of the cylinder. And if it does, how does it differ from flatness?
The runout tolerance uses the other flat surface as its primary datum. It uses an outer diameter as its secondary datum. The print appears to have been created in the late 1960's.
I appreciate your help.
