Hi All,
Recently I saw a drawing where the runout control is referenced with axis of pattern of holes as the datum. I doubt whether it is a legal specification for runout?
Please see the attached drawing.
The four holes dia 10-11 are the clearance holes, the disk will be mounted to a spinning part using the fasterners.
I understood that dia 9.8 gauge pins located on a PCD of 100mm can be used to varify the position of the 4 holes. Also I understood that using M modifier is a must when we use pattern of holes as a datum. I have no doubt on this.
The question is, the outer diameter of the disk is controlled with respect to the 4 hole pattern using runout , How is this possible?
because the datum B is the axis derived from the pattern of 4 fixed gauge pins of size 9.8. How to simulate the datum B here? will there not be any play between the holes and the datum simulator? obviously there will be a play - How to measure runout for this.
Can any one help me to understand this doubt.
