I Work in Ammonia/Urea Plant in Turbomachinery Maintenance. One of the steam turbines in the plant drives electrical generator to supply the plant with electricity. Sometimes in case of steam shortage in the plant, generator turbine is switched off, and power is supplied from the grid. This can take place two or three times per month.
From the electrical perspective, is there any danger for the Generator if the turbine-generator train is kept running at operating speed without synchronization during steam shortage time instead of starting-up and shutting down the turbine?
What could be measured, must be measured exactly.
