We have a slow speed machine with a pair of 5 foot diameter journal bearings. the top half of the journal is open, and oil is sprayed on the journal from above. The bottom of each bearing housing forms a sump well below the level of the seal, and has a 2 inch drain pipe pitched down hill to the lube skid. On either side of each bearing is grease filled labyrinth seal. The labyrinth ring is stationary and has a large O-ring on its OD compressed about 20%, intended to seal against a bore in the main housing. One seal leaks one drop every 10-30 seconds. There is suspicion that the housing bore has a scratch or other damage that the O-ring can not effectively seal.
I've been daydreaming about just pulling a few inches of vacuum on the skid breather for the purpose of reducing or eliminating the leak.
Immediate potential downsides are:
- pumping some amount of oily vapor into the shop ( solution - coalescing filter)
- possibly pulling dirt past the seals, or in thru poorly sealed components
- finding a fan and motor suitable for pulling oily vapor safely. ( solution - Using a tiny amount of seal air for venturi extraction )
Any thoughts?
thanks
Dan T
Any thoughts?
thanks
Dan T
