Run-Time error '-2147319779 (8002801d)' 2
SteffiCrown
Computer
DE
thread561-317114
I have the same problem like in thread561-317114.
Are there any solutions?
"I am running NX8 on a Windows7 64-bit machine with Office 2010 installed.
In NX8 I click TOOLS>SPREADSHEET and Excel 2010 opens.
I click ADD-INS>EXTRACT ATTR and then I get an error:
Run-Time error '-2147319779 (8002801d)':
Automation error
Library not registered.
If I click EXTRACT ATTR again I get:
Run-Time error'91':
Object variable or Width block variable not set."
Thank you
You may try the following:
Step 1. Go to Run Prompt and Type “regedit” and click ok
Step 2. Expand HKEY_LOCAL_MACHINE
Step 3. Expand Classes
Step 4. Expand TypLib
Step 5. Expand 00020813-0000-0000-C000-000000000046
Step 6. Select 1.8
Step 7. Right Click on 1.8 and Delete this.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
Thank you. But it doesn't work :(
I have the problem with nearly 40 machines. I could cry.
Yes, ug.xla is in this folder.
I checked my UG Version, Its UGS NX 7.5.0.32 (64bit)
Is there any possibility to check logfiles at UG ?
Yes, beneath the help tab...
Best regards,
Michaël.
Win 7 64 bit
Are there any knows Programms/Tools, which can also cause this error?
Try patching it to NX 7.5.5.4... and see if problem still occurs.
Or if you can provide the part?
Best regards,
Michaël.
Win 7 64 bit
i will try, where can i find NX patches? Sorry, for the "stupid" questions, but i am new in this Software area.
You will need a web key to login of course. Look beneath the Help tab in NX - About NX then system info, there is a line which state WebKey Access Code, with this code you can create a login account for the gtac site...
Best regards,
Michaël.
Win 7 64 bit
thanks, i will try this.
Now we have 2 workstations, which are working without problems. (Win 7 Pro, 64 bit) NX 7.5.1.5
Other WS with problems use NX 7.5.4.4 (also W7 Pro 64bit)
Is there a possibility to de-install the patch 7.5.4.4 for testing?
We found a solution!
You need register excelitf.dll at <Install_folder>\UGII
