martinakenic
Hi to all,
I was wonder could anyone explain how works run around coil, I read a lot of about this and I notice that in some system loop we have a three way valve , and some work with two way valve or just with pump frequency regulated. If I correctly understand it well, we use a three way valve in cold climate (if we have a temparature below zero?) to prevent a freezeng coil and also if we want to control temparature supply air, but iam not sure about this, and also Iam not sure when we use two way vale and do we need two way valve at all or is it in this case do we need just pumps freq. regulated.
Do we have some recomendation and standards about this , good praxis case?
Thanks.
Thanks.
