Run APPLOAD from VBA
CanonShooter
How do you tell AutoCAD to run APPLOAD on a certain "application or file", from inside a VBA program? Also, I'd prefer to not have to pick the app from the APPLOAD dialog.
TIA
Hi CanonShooter,
Code:
Application.LoadDVB "File.DVB"
HTH
Todd
Thanks. I got it load (using loadARX instead), but I appreciate it.
Now I need to run the dumb thing once it is loaded. When I load it using APPLOAD, it executes itself, but when I do it in VB, it just loads.
I'm all fixed up...except for the dumb Macro Enable warning message that pops up. MIS wants it to continue to pop up, but I don't see a list of safe ones, or a way in, say, the ACAD Startup to disable it, load a VBApp, and then re-enable it.
If anybody knows, let me know...
TIA
