Rule of thumb or technical standard for industrial fan 1
Maaruf Bussri
I want to design a centrifugal fan for transporting wood dust. Is there any rule of thumb or technical standard for industrial fan? For example, size of hub, blade thickness, shaft diameter, materials etc.
Maruf,
This is your first post here so not sure what you expect to get, but these sorts of things are the details that only vendors know.
Wood dust didn't normally go through the fan element.
Wood dust is explosive so be careful but many people already make such units.
Thé book Fan Engineering published by Buffalo Forge, now Howden, has some good information. Engineering Letters by New York Blower NYB.com also may be helpful.
Brian,
I thought about that as well.
LittleInch,
Yeah, probably each manufacturer have their own standard and its confidential.
I agree. Wood dust is like a combustible gas. A little spark would create fire or explosion. For example metal-on-metal contact at high speed.
dvd,
Thanks. I will definitely check it out.
If you want to build a fan, you should.
Check out AMCA, also.
Spark-resistant fans are not uncommon.
