We are designing a part to replace an unsatisfactory commercial component.
Pretty much a metalastik type bushing with a steel inner and outer sleeve.
Reportedly the rubber filling is some version of natural rubber.
To specify a good replacement "rubber" we are going to start by confirming the the properties of the original part.
We won't be buying the rubber directly, but will need some information to specify a decent performing replacement material.
For instance if we are considering a urethane replacement we might want similar stiffness, elongation without tearing, etc,
A rubber lab has proposed all of these tests.
• Polymer ID by FTIR – ID of polymers present
• Thermogravimetric Analysis - % breakdown of polymer/plasticizer and fillers
• Extraction and Qualitative Analysis of Extract by GC-MS – ID of plasticizers
• Sulfur Content by Ion Chromatography – overall sulfur content in cure system
• Metal Content by ICP – quantitative analysis of Zinc levels, along with detection of other metals
• Organic Filler Analysis by SEM (Ash to 450C) – analysis of organic fillers present
• Inorganic Filler Analysis by SEM (Ash to 800C) – analysis of inorganic fillers present
• Sample Extraction for Physical Testing – sample prep from provided material
• Specific Gravity - Density
• Hardness (Shore A)
• Tensile Strength – ultimate tensile/elongation
• Drum Abrasion – Abrasion resistance of the material
• Pendulum Rebound – rebound properties
• Outline of suspected formulation based on collected results
I'm thinking some of them are not needed. For instance I'd skip the Abrasion resistance, specific gravity, and ID of plasticizers and fillers.
Any insight is appreciated.
