RSLogix 5
Keldog
CA
Hello i have a quick question for you guys if don't mind answering it.
I opened a existing PLC5 program and then saved it as a different name and made some modifications and now that i've saved it. The new file i made the changes to is smaller then the original. The original is 1042KB and the new one i made modifications to is 746KB is this a normal thing or did something not save maybe.
Thanks alot in advance for your help
I think this is probably normal.
I know that with Logix5000 there is a "compact" instruction under the "File" pulldown menu, which allows you to compact the database. This can reslut in file size reductions like you mentioned.
I don't happen to have Logix5 installed at the moment, but my guess is that when you created a new file, by saving as a different filename, the database was compacted.
whenn you open the program, does it look Right? Documentation, I/O, the ladder or ladders itself, ect.?
Yeah the program looks fine. It is probably just something that happenes.
Thanks alot for your input
This happens in RSLOGIX 500 as well when you do a save as it cleans up the revision notes and history of the file.
The program, when "saved as" saves only the offline program.
It does not contain the online image, which may only be created once the program is downloaded to a processor and online save adds the online image.
