Can any one help. I need to make a one-way Digital I/O connection between to devices. The output signal from device A is 24V (high). However The input device can only be configured to recieve TTL or RS422. TTL is 5V max(right?). Rs422 is 6V max (right?). If thse assumptions are right then I can't connect them directly (right?). What can I use as an interface between the two?
Thanks in advance, Churchie1
