Hi
I have a problem as i need to write a simple comm's program to send one hex string to the serial port.. Ideally i would like this program to be a single .exe file that when run just sends the hex string and closes the port..
Also
-It needs to run in win2k
-It needs to run hidden but i assume that if it was an .exe i could just use hidden32.exe to hide it..
-I might need to send a different hex string in the future so it would be best to have an easy source file to edit..
Thats it really... I have searched and searched the net but cant seem to find any pre-made program that would be suitable... However i did find a few C++ and VB libraries that might be able to be edited...
I dont have any idea of what would be the best lanugage to use as i dont have any particular knowledge of any one lanugage but am willing to give it a go... If u have any input on the best lanugage and other info places to look or even a program that u have come across on your travels that might do the job or even a source code it will be apperciated..
And if u are able to reply please the more indepth the better...
Thank You
Also
Thank You
