Crystalct1
When establishing a relationship between outflow and elevation, it is easy to see which equations to use for culverts or bridges flowing full or overtopping the roadway. What is the best way to calculate outflow from a bridge in low flow conditions? Would that be considered weir flow? or open channel flow?
Weir flow seems appropriate since it accounts for the constriction of flow at the opening, but H (height above "weir") wouldn't make sense - unless you use an average height above stream bottom? Would that make sense?
Open channel flow would be complicated because you'd have to take wetted perimeter and area at each elevation. Although, HEC RAS could do that - I already have a running model.
What has everyone else done?
