Minrob, after selecting the edges RMB, Make Transition. You can also RMB again and investigate the different types of transitions that may be available (will depend on existing geometry). You can also do it all via the "slide up" and list boxes on the dash panel.
James, you can indeed just re-order features (in this particular situation) but you'd want to replace the chamfer with a revolved cut to preserve what I imagine to be the intent. The chamfer following the R75 no longer represents a conic face.
