Modifying multi-Rounds
  • Thread starter Thread starter Roland J
  • Start date Start date
R
Roland J
Guest
I have applied a number of rounded edges within one feature. I now want to change the Radius (same change to all) but it appears I have to visit each one individually to make the change! Is there no way of doing a "one click" modification to change all at once?
Many thanks in advance
Roland
UsingProE W5.
did you make all the rounds in one set, or in several sets? (sounds more like you made then in several sets..)
When you pick your edge to round, hold down ctrl and pick all the edges so they appear in the same set, then you just have to change "one time" to get all the rounds to update.
//Tobias
Brilliant!
Thanks for the quick reply....
.... and the solution of course
