Walterke
Industrial
- Jun 22, 2011
- 451
Is there a way to round off a number to the nearest 10mm?
As in 2786mm would become 2790mm?
NX 7.5
Teamcenter 8
NX 7.5
Teamcenter 8
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
You can override the dimension text and add your own 'manual' text entry. This is generally frowned upon as "bad practice", but if you understand and are willing to manage the risks (model changes, dimensions do not), you can change the text by going to Edit -> Annotation -> Text.... As you enter new text you will get a warning message.Walterke said:Thanks John I was afraid that would be the answer. I'm assuming there is no other way around it then to add the requested dimension as a note and put the real dimension on a very tiny size.
That's the problem, it happens very randomly. Then again, changing it once usually fixes the problem, so it's not that big of a deal.if you're able to duplicate it on demand.
