rounding off parameter
  • Thread starter Thread starter robo_kk
  • Start date Start date
R
robo_kk
Guest
I have a quick question. When I make a drawing and i take dimensions from parameters, i get three zeros after decimal. How can i round it to one zero or none?
Thanks,
Robert
After the parameter, use [.x], where x is the number of decimal places.
thank you robertib!
As a side note. I know when I do this on a drawing I often also need to drop a leading zero in the parameter.
You can do this my editing the "lead_trail_zeros_scope" option in the dtl file. It defaults to "dims" only. If you set this option to "all" it will drop leading zeros from parameters references in notes etc.
