Round off the Dim Values
  • Thread starter Thread starter salil
  • Start date Start date
S
salil
Guest
Anybody can guide me regarding this, let me brief my problem,
In the drawing of a part modelwhich is modelled in the unit
set as inch & the drawing is made as setting mm as primary units & inches in the secondary.As Primary[secondary]
if suppose there is a Dim.
140.5-142.4
[5.54-5.60]
While actually the dims in inches is 5.532-5.606 when the Dual decimal places is changed to 3 ( previously it was 2) now if suppose i again changes it to 2 it gives 5.54-5.60 & the observation is it has rounded off the 5.532 to 5.54 & 5.606 is not changed to 5.61, I wanted to know Why?
Can it be done because I want the dim as
140.5-142.4
[5.54-5.61]
Same thing I also observed while setting up the Geom tolerances.
Thanks In Advance,
Salil.
Salil,
Not sure if you are still interested, but I would like to direct you to a thread on the www.eng-tips.com forum that will help you determine the correct number of significant figures to display:
Aeronautic Engineers > Activities > Aeronautic engineering other topics Forum
Thread: Help Plz! Rouding off confusion?
http://www.eng-tips.com/viewthread.cfm?SQID=30869&SPID=16&newpid=16&page=5
Please note that there was some confusion over this topic, but poster CoryPad is correct.
Sorry I am not addressing the specifics of the issue in Pro/E. I hope you find this information valuable regardless.
Best regards,
Matthew Ian Loew
Pro/E truncates secondary dimensions, rather than rounding them...
This means that conversions sometimes don't appear to come out correctly.
(It's meant to make the primary dimension the main driver, but I know it's a real pain...)
One possibility is to change the primary dimension slightly, for example:
(primary show 1 dp, secondary show 2 dp)
0.500mm >> 0.5mm
0.019685 inch >> 0.01 inch
Workaround - set primary to 0.51mm, show 1 dec pl:
0.510mm >> 0.5mm
0.020078 inch >> 0.02 inch
