Rotor (pin) speed reduces when assembled on another aseembly
  • Thread starter Thread starter CADfan
  • Start date Start date
C
CADfan
Guest
Dear all,
I am facing a problem in Creo mechanism, i.e I have rotor with three blades mounted on it. I gave pin connection for the rotor.That's ok. The rotor alone spins nicely. Then i assembled the rotor into the another assembly, there its rotational speed has reduced.(almost one-fourh) I don't know, Why the speed of the rotor reduces.For rotor i gave 720 deg/sec. It span fast. Then i haven't changed anything. The same rotor used in the another assembly.
Can anybody tell me why there is reduction in the speed. And how to correct it.
CADfan
