PaulPounds
New member
Greetings all!
It's been a long time since I've had a chance to check out the forum, so I need to catch up. While I'm going through the archives, here's my question du jour:
I have a rotor that is a drive unit for this four-rotor robot I'm constructing. To design the attitude controller, I have a single motor mounted vertically on a lever arm with a PID controller and an IMU. I've tuned the controller so that it should be stable and stationary, but I keep getting oscillations.
The rotor will occasionally dip up to 5 degrees in a way that doesn't seem related to the control. My current theory is that it might be a result of the rotor being in ground effect. I've seen a few things about rotors losing power in certain ground effect conditions - does this sound like a likely culprit?
Thoughts?
take care,
-Paul
Un
Thoughts?
take care,
-Paul
Un
