Hello all,
Thanks you very much for your repsonds!
MSC Nastran is the solver. I was asked to apply just 1rad/s^2 in the x dir (as for trial run) to a node that connect to the rest of the component by a RBE 2 element. In patran window, I go to Loads/Load BC / Create/Acceleration/Input Data, then under Rot Accel I entered <1,0,0> for 1 rad/s^2 in the x-dir. Am I input the right value? I understood that it should be entered in radians.
Many thanks
Thiet
