Rotating part in exploded assembly view
  • Thread starter Thread starter Army
  • Start date Start date
A
Army
Guest
Is it possible to rotate a part around an axis in an exploded assembly model? An example would be say I have a clock and want to rotate a hand from the 3 o'clock position to the 7 o'clock position. Any help would be appreciated.
hello
Try to use family tables option for the solution to your problem
For example you mentioned above.. create a family table which has the info angle, so in your instance the hand from 3 o
When you set up the exploded view - select the centre axis to rotate around, and pick the component - then drag it round the axis.
