1st time posting here and I'm not sure if this is where I should post my question, so feel free to move it if it's not.
For my project (an inertia dyno) I need to spin a pair of rollers at roughly 4lbs each at roughly 4500 rpm's. The rollers are Ø3" and will be made from mild steel which will be welded onto a Ø5/8 or Ø3/4" shaft. My plan is to have both rollers welded onto the same shaft, but I may have to use 2 shorter shafts and couple them together. I plan to have the diameters of the rollers turned once they are welded to the shaft so everything is on the same centerline to help eliminate vibration. I'm going to have a bearing on each side of each roller.
Obviously I don't want anybody getting hurt as this will be used as an educational tool so I want to make sure this is safe. Does anybody see any problems with what I'm trying to do?
Instead of 2 separate rollers I can make it one roller about Ø2" in diameter about 13" long to get the same moment of inertia, but my thinking is because the roller will now have to spin at 6500 rpm's I'll have problems with the center of the shaft trying to bend and causing more problems. I would be concerned if I had a good way to add a bearing and support in the center, but a bearing with a 2" ID is quite costly.
Any ideas, or directions anybody can give would be greatly appreciated.
