  • Congratulations IRstuff on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Rotated stiffness values of a skewed pile bent 3
AR_PE
1
The stiffness of a non-integral 5 column pile bent can be idealized as [5 piles]*12EI/h^3 for the transverse direction (along the bent - assuming a fixed-fixed condition) and [5 piles]*3EI/h^3 for the longitudinal direction (perpendicular to the bent - assuming a fixed-pinned condition). My question is, for a skewed bent, how would you calculate the stiffness of the bent in the global axes direction of the bridge? - Put another way, I can calculate by hand the stiffness of the skewed bent along its local axes with 12EI/h^3 and 3EI/h^3. I am unsure of how to resolve these stiffnesses into the global axes direction of the bridge, which are rotated by the skew angle.
I know this is very simple to model, and I've already done so. I'm just wanting to prove to myself that the numbers provided by the model are valid.
Here's the model for your system:
You have a diagonal load resisted by two springs with different stiffnesses. You can determine the diagonal stiffness by splitting up the applied load, P, into its X and Y components. Then determine the displacements in the X and Y directions. Then combine them to determine the total displacement. Diagonal stiffness is then P/Delta.
Structural Central
I feel that programmingPE's solution needs a minor tweak as follows:
ProgrammingPE said:
Diagonal stiffness is then P/Delta P/(component of Delta parallel to P).
That, because the combined [Delta] won't be parallel to [P].
