Quick and simple fix ... Rotate the drawing view to suit.
Possible permanent fix ... If the first component in the Feature Manager is fixed (ie it has a small (f) prefixed to its name), right click the component and select Float. If you are really lucky, the whole assy will now be rotatable. If it is, create mates to position it to your needs. If it isn't rotatable, use the "Quick and simple fix".
