what will happen if a rotary screw compressor discharge air flow restricted,
we have a rotary screw compressor 10 bar 20 nm3/min, when the compressor started it tripped by inter-stage pressure high. the trip was 16 seconds from start-up
when the compressor checked after trip,the 2nd stage found defected and the drive shaft of the 2nd stage found broken.the mechanical maintenance suspecting that the compressor started on closed discharge valve, but even if that happened the compressor is equipped with pressure relief valve which suppose to open and protect the compressor.
Assuming discharge air flow restricted, would the compressor in 16 seconds increase air pressure to tremendous values that would break the 2nd stage.
attached is a photo of 2nd stage broken shaft
