Rotary Coupler
Speedy
DE
I have an application where i want to feed 4 seperate water pipes and a common return to a table that is rotating on a central shaft. I require a ROTARY COUPLER that will fit on over the shaft, approx 100mm dia, and will feed the water through as the table rotates.
I did a search but could only find ones for hydraulic feed.
Any help gretaly appreciated.
Cheers,
Speedy
[banghead][banghead]
These are often referred to as deublin unions. Seems that Deublin has thier own website.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of Eng-Tips Forums?
Madmango, thanks very much for that!
My problem is that there is a solid shaft in the middle of the table.
Are there any ring type rotary couplers that allow for a shaft to fit up through the middle?
Cheers,
Speedy
