During a MT inspection I found a centerlien crack, about 1/6" (1.6mm) in length. Carefully grinding the crack out it was almost 4" inches in length when we got near the root.
Found this crack on 16% of welds on this project. Currently, doing a weld metal analysis, checking WPS against what was used, and checking mill certs, on material. We have been using this WPS and filler material for 5 years without problem. crackis in welds by multiple welders, using multiple machines. A little baffling.
These welds are in tension and are cyclic, fatigue could be a problem. The Technical Engineering Manager for the wire vendor will be here tomorrow and I am currently working with Edison Welding Institute to determine cause.
