chinmayhegde
Bioengineer
- Sep 3, 2010
- 2
Hi all,
I'm installing solar panels on my home and the structural engineer I'm working with determined that my current roof will not support the weight of the panels. My roof (built in 1967) is comprised of a field fabricated truss with a 2x8 ridge plate running along the top of the roof, 2x6 rafters, and two diagonal members per side of the roof, a 2x4 and a 1x5. See attached for a layout of the rafters and a layout of the solar panel system.
The total weight for the solar panels, plus racking, etc. would be in the ballpark of 900 lbs. There are currently 2 layers of asphalt shingles on the roof but I'm having a new roof put on so there will be only one layer when the panels are put on.
Based on the engineer's analysis, he recommended sistering a 2x8 to every rafter and adding a 2x6 collar tie every other rafter. However, because of the layout of the diagonal members, it is not possible to add the sister members in the same plane and thus they could not be connected by the collar ties. Hopefully this statement makes sense. To clarify, if you look at the rafter diagram and consider the z axis as coming out of the page - the diagonal members on either side of the roof would be at say +2" in the Z direction on one side, and at -2" in the Z direction on the other side, and thus the sister members could not be put in the same XY plane.
So, the engineer is coming back out next week to see what alternatives there might be to sistering in new rafters.
My questions are the following:
1. Is there a good alternative to sistering? (I came upon this site because of an interesting discussion on using a coil strap, but I think the poster ended up sistering anyway).
2. Is is necessary to sister all the rafters, when only a select number will be exposed to a point load from the solar panels?
3. From an intuitive standpoint, if I have 2 layers of shingles currently on the roof, when I remove them and add just one back plus the solar panels, I will likely have less weight than what is currently on the roof (though the load distribution will be different, hence Question 2). If this is the case, doesn't that mean my current structure is unsound, or at least not up to code?
Thanks for reading! I appreciate any insight the forum can provide.
