We have a large flat metal deck roof on 100 ft long steel joist @ 6 ft OC. The mechanical contractor has recently replaced 3 roof top units (Air Handling Units) with 3 new and lighter ones (approx 8 kip each). After the old units were removed and the new units installed several people working on the roof felt that the roof is somehow bouncing upwards (pop upwards) with no apparent reason. It is not vibrating. Just a small bounce and then nothing for an hour or so. We have no snow yet and the only load present is the dead weight plus the unit weight approx 8 kips shared by 5 joists about 15 ft from the edge.
Any thoughts?
Thank you
Any thoughts?
Thank you
