Stugots
- Aug 11, 2005
- 43
I am helping a coworker and have a rolled sheetmetal part with cut holes in it. I can not dimension them in the flat pattern in a drawing. I can't select the holes in the flat view..."The selected entities could not be converted into a line or arc." is what I get. I've tried holding the "SHIFT" key down and no luck.
I understand that it is not making the hole axis perpendicular to the flat pattern plane so it is making the circle into segments. Is there a way around this?
On a side note: Solid Edge doesn't have a problem with this sort of thing because you are able to flatten sheetmetal by selecting either a face or "PLANE" for your flat and then blow holes in it and it forms the holes onto your bend when you suppress the flat. Am I missing something here? Please view the part model path below.
Stugots
Mechanical Designer
SW '06 SP5.1
Stugots
Mechanical Designer
SW '06 SP5.1
