Role of spine
  • Thread starter Thread starter rachna
  • Start date Start date
R
rachna
Guest
In catia v5 there are a lot of command where we can see a term "spine".Can anybody tell me about the importence of spine in these commands(VARIABLE FILLET ETC.)With example.
THANKS
Some comments, mini guide and sample file:
» In catia v5 there are a lot of command where we can see a term "spine".Can
» anybody tell me about the importence of spine in these commands(VARIABLE
» FILLET ETC.)With example.
» THANKS
Hello rachna,
The use of a spine curve in variable filleting, swept and lofted surfaces is generally used as a guide curve to orient the cross-section of the feature as it moves along its path.
For example during a variable radius fillet, the propagation along the edge(s) can be done smoothly when selecting a spine along which an arc of circle is slid. Cutting the resulting fillet surface by a plane normal to the spine would result in a circle of the specified radius value.
Here is a V5 Mini Guide on Creating Variable Bi-Tangent Circle Radius Fillets
Using a Spine:
http://pop.dia.uniroma3.it/catia/online/sdgug_C2/sdgugbt0326.htm
Here is the sample document that goes along with the guide:
http://pop.dia.uniroma3.it/catia/online/sdgug_C2/samples/FilletVariableRadius2.CATPart
Thanks for asking the Q&A Board
3DCADTips Support
