Rocscience RS2 Excavation Help
Geodude7
Geotechnical
CA
I am using Rocscience RS2 to model excavations for HDD analysis. I wanted to used a staged excavation to simulate a pile hole followed by a reaming hole. I noticed if I set it up as
Stage 1: As is
Stage 2: Pilot hole excavation
Stage 3: Reaming excavation
That I am unable to create a larger excavation around the pilot hole excavation since the program does not allow you to create an excavation boundary that crosses another excavation boundary.
I can create a second analysis that would go from as is to the reaming sized excavation if need be but I wanted to check in and see if anyone knows a way to simulate this without creating multiple files as I am planning to use these models in future on multiple analyses.
Thanks in advance for any help.
What are you trying to achieve? Research project?
