Great advice from Phillyfrank. Get excessive Videos and Stills with the pre-blast survey. Document the heck out of the situation. Have you tried taking out the rock with a hoe-ram? Some softer rocks will lend themselves to this. Noise can be a problem here though. But then, drilling can be as well. Are you blasting close to other utilities? Make awfully sure that the area has been "Dig-Safed" and any necessary exploratory test pits have been dug and recorded. Don't make friends with the residents but be sensitive to their needs. Blasting is a very High Profile venture and some people treat it like some treat workmen's comp. Err on the side of conservatism, and document, document, document.
Watch location of magazines, or that all explosives are in appropriate transportable magazines. Expect visits from your, or the contractor's insurance agent and potentially OSHA. Be particularly vigilant with inspection of the installation, the residents will get only more miffed if you have to go back in for a bad joint during a hydro-test as they were when you were doing the original blasting. Blast appropriately, enough, but no too much so you minimize need for excessive amounts of imported select backfill. Pay the Contractor to designated (specified)Pay Lines to avoid him from overblasting. Make the select replacement material part of the removal item, if it's not too late,that'll help keep him honest.
Good Luck
R.A. Hassett, P.E.
