Fluorescence
- Oct 19, 2008
- 42
I am trying to work out the RMS ripple current in the DC Electrolytic Caps that occur just after the diode bridge rectifier in my 10W offline SMPS.
I apologise for the lengthiness of this post.
It is a one transistor forward converter (Mains is 240V, 50Hz).
Here is the representation of these caps…
C BUS CAPS:
The capacitance has been kept low so as to improve the diode bridge conduction time and hence improve the power factor.
The capacitance is only 1.47Uf (with total ESR of 180R).
(Jamicon TK electrolytic caps)
Here is the voltage waveform on these caps….
:CAPACITOR'S VOLTAGE WAVEFORM:
Is it right that……
1. During ‘A’ the caps alone supply current to the SMPS ?
2. During ‘C’ the mains alone supplies the SMPS current since the caps are being charged up ?
3. During ‘D’ both the mains and the caps supply current to the SMPS, but since the caps have an ESR of 180R, the mains will supply the majority of the current during this period ‘D’ ?
Is this correct for how the current in the capacitors would look like ?….......
:CAPACITOR CURRENT WAVEFORM:
If it is correct, how can I calculate the RMS value of this current ?….i.e. the ripple current in these caps ?
I am thinking that over several cycles, the RMS current going into the caps must equal the RMS current coming out of the caps (?)
Therefore, if I simply calculate the rms value of the current going into the caps (the charging current in period ‘C’), then double this value…….does that then give the total RMS ripple current experienced by the caps ?
Most grateful for your reading and any thoughts at all greatly appreciated.
Is it right that……
