struct6
- Apr 22, 2008
- 16
I am designing a ring wall foundation for a tank which is 32 ft tall and 22 ft dia. I have designed the ring wall itself and now working on the footing part of the ring wall. I am planning to use a 4 ft wide footing. Since this footing will have both axial load and lateral moment due ti wind i will have to determine whether the resultant of the forces will fall within the kern limit. how do i find the kern limit for a circular footing whose Outer Diameter is 25' and Inner diameter is 21'.
Thank you
Thank you
