SeanMD
- Jun 17, 2005
- 53
Design of a ringwall tank foundation, (ringwall required by owner).
I have proportioned and designed the fdn so the soil pressure under the fdn is the same as the soil pressure under the tank (at the same depth as b/fdn), which I think is pretty standard practice to attempt to limit differential settlement. Thing is, these pressures are totally dependant on fluid height, and in the long term the fluid height will not be constant. For example, right now they balance at 3/4 height, but they are about 500 psf off at full fluid height.
Does it make sense to try and balance the pressure under the max fluid level condition where the most settlement will occur, or at some average fluid height, at say 3/4 full, since in the long term the fluid height is always changing?
