RING JOINT GASKET/FLANGES
patsand99
Hi all
Can somebody help me with a FE, for a bolted flanges 10"ANSI 2500, sch 100, this is bolted through a transition oval ring gasket R 55
Probably - done that type of analysis before. What do you need?
I NEED TO PERFORM A FE, OF 10" OVAL TRANSITION RING GASKETS, ANSI 2500#, WITH TWO FLANGES RTJ, 10" ANSI 2500 SCH 100, ASTM 694 F 60,PLEASE LET ME KNOW IF YOU CAN HELP ME WITH THIS ISSUE.
THANKS
PATRICK
I can probably help. Are you looking for free advice or paid services?
Oh - and next time lay off the ALL CAPS. There's no need to shout.
Hi
Is it possible a free advice?
Possible - ask your question. Please make your question as specific as possible. If your question involves more than what can be given for free - we will let you know.
HI
We did an oval transition ring R55/R51, in order to adjust flanges 10"ANSI 2500 A 694 F60, with different groove sizes. In the valve side the flange groove is OK, but in the piping side the groove is below the specs . The groove size is 13/16" , but the same pitch diameter.
Also we performed a hydrotest for this job at a 5,860 psi, by 12 hours, and it was OK, but I need to be sure under normal operation conditions If I will not have problems with this transition ring. The diameter of the stud bolts are 2 1/2" and the torque is 4,400 pounds-feet.
Thanks is advance for your cooperation, I am enclosing a drawing of the flange and ring.
 http://files.engineering.com/getfile.aspx?folder=0dea0c48-13f1-41af-aa2f-6d60f4a85378&file=Flange_detail.pdf
You may or may not have a problem, depending on the operation of the flange. For example, the operating and design conditions, including pressure AND temperature, external bending moments from attached piping and attached piping restrained free thermal expansion.
If you want someone to do the analysis for you, you will have to pay a consultant for that.
