A couple of thoughts:
First is that vehicle manufacturers typically have different bolt pattern between cars and trucks to distinguish between wheels designed for each - with the obvious difference being the load.
Second is the use of the term "vender". This term is usually used in the trade to describe a supplier of goods or services to another business - and not to describe the relationship between an individual consumer and a retail outlet.
So if your intention is to buy a large number of the same part for your manufacturering process, the term "vender" would be appropriate - and you will need to describe the service conditions to the vender. They, of course, will check to be sure that the parts they make are suitable for those conditions. But if you are going through a wholesaler, the that wholesaler should check with the manufacturer for such info.
But if you are a consumer doing your personal car or truck, then it is quite likely that the bolt pattern will determine what is available to fit and you can be reasonably sure the wheel manufacturer considered loading in the design process.
But if you are doing a modification - particularly if you are doing something along the lines of increasing the load carrying capacity of your 1/2 ton pickup - well, there are many more issues involved than just the wheel (and tires). Frames, suspension pieces, brakes, etc. would also need to be upgraded -something usually not considered. If this is the case, my personal advice would be upgrade the whole truck.
And lastly, use of the CAPSLOCK is considered shouting in internet postings. It should be done sparingly if you want to be treated like a resonable person. The first impression you leave with a posting with all caps is that you are a jerk. It'sobvious the group here looked passed that, but other groups are not so forgiving.
