I am trying to run GMNIA analysis for the wind turbine monopile. I have obtained the imperfection based on the the standard as 0.00538. Initially I did a linear buckling analysis in abaqus in order to get critical load. I have applied 1N force in y direction and obtained 2105000 as the load multiplier. Next I run Riks analysis and I have applied the load of 2105000 N, and also introduced the imperfection stated above for the first buckling mode to the keyword. My question is how to adjust to arc length increments and what to use as the stopping criteria? Am I following the right procedure?
My other question is about the load proportionality factor. Do I need to obtain this from the field history output when the simulation finish or this is something that I can obtained now prior to finishing the simulation?
Any help is greatly appreciated.
Ariyan
Ariyan
